using measurement computing 1408 to read encoder
im trying to count revolutions and calculate speed using an encoder (3 digital channels output - A,B,Index) and an mcc 1408FS DAQ.
does anyone has a VI for this application?
im new to labview and tried to do this myself but no success so far
(3,004 Views)
Hello sitzikbs,
There are many community and shipping examples that will help you get started.  You will not likely find any single example that meets your specific project needs, but they are always a fantastic place to start.
Here are some resources available on National Instruments' website:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
https://forums.ni.com/t5/Student-Projects/Angular-Position-Measurement-with-a-Quadrature-Encoder/ta-...
https://forums.ni.com/t5/Example-Code/Use-Counter-Frequency-to-obtain-an-Encoder-Rotational-Speed/ta...
and if you would rather work with shipping examples, there are many that may be accessed by using the Example Finder.  Four that are particularly applicable may be found:
Help » Find Examples
With the browse tab selected, navigate to the following folder:
Hardware Input and Output » DAQmx » Counter Measurements » Position
Best regards.
Matthew H.
(2,986 Views)
