Multifunction DAQ
using the NI 4350 with DAQ assistant
Hello. I am trying to use my NI 4350 PC Card in in the DAQ Assistant and am having issues. When I open up the MAX the deviced is there and appears to be working properly, however, when I open the DAQ assistant Express VI that I have placed in my block diagram and try to add a voltage channel to the channels list, I am left with a message saying there is no supported device found under the physical channels list. has anyone had this problem before? does anyone have any suggestions?
Chris
(3,280 Views)
It is a very old device and it is only supported with what is called the traditional DAQ driver. In order to use the DAQ Assistant, you need to have a device supported with the current driver which is called DAQmx. You can still use your device if you have the correct version of traditional DAQ installed (7.4.4) and you use the traditonal DAQ palette.
(3,276 Views)
Thank You for the post. I will try that and post back my results.
(3,270 Views)
Hello Chris,
Dennis is correct that the NI 4350 only works with Traditional DAQ.  I also wanted to mention that there is a driver made specifically for the 435x series of devices which is based on Traditional DAQ.  You can download the latest version of the NI 435x driver here:  Drivers and Updates
Have a great weekend!
Brooks
(3,257 Views)
Hello Brooks,
Thank you for the information I have found the instrument driver you mentioned and have downloaded it. I also am in the process of downloading the traditional DAQ that Dennis mentioned so with both of these solutions I should be well on my way first thing next week.
Thanks again,
Chris
(3,250 Views)
