Multifunction DAQ
vary the output voltage value of the Digital output HIGH.
Is it possible to vary the output HIGH voltage values of the NI DAQ.If so please tell me how to do the same.I want to reduce the voltage before feeding the signal from the Digital output to my device, as my device rating is only 3 volt for the digital HIGH.
Pradeep.
(2,978 Views)
Accepted by labviewzoomer
The digital output voltages cannot be varied on your USB 6259 (which you mentioned you were using in a different thread).  Please refer to the specifications for more information about the digital logic levels used on your board.
Best Regards,
John Passiak
(2,976 Views)
