   I made a vi to scan temperatures from a SCXI-1100 module housed in a SCXI-1000 chassis. I am using a PCI 6052 E-Series DAQ board. I checked everything that I know, the chassis power was on, the thermocouples were connected, the terminal block was also connected, the DAQ board was connected to the chassis using a 68 pin connector (SCXI-1349). The MAX is identifies the DAQ board and the chassis as well. But when I run my vi, I do not see the temperatures at all, all I see is some highly fluctuating noises. I switched the chassis power off and unplugged the DAQ board and ran the vi again. I got the same highly fluctuating nosises. So looks like it does not make any difference to the vi weather the hardware is there or n
ot !! is there anything wrong with this vi, I am attaching the vi. I will really appreciate if someone can resolve this before monday !!
Thanks a lot !!
