vi does not seem to respond to hardware
I made a vi to scan temperatures from a SCXI-1100 module housed in a SCXI-1000 chassis. I am using a PCI 6052 E-Series DAQ board. I checked everything that I know, the chassis power was on, the thermocouples were connected, the terminal block was also connected, the DAQ board was connected to the chassis using a 68 pin connector (SCXI-1349). The MAX is identifies the DAQ board and the chassis as well. But when I run my vi, I do not see the temperatures at all, all I see is some highly fluctuating noises. I switched the chassis power off and unplugged the DAQ board and ran the vi again. I got the same highly fluctuating nosises. So looks like it does not make any difference to the vi weather the hardware is there or n
ot !! is there anything wrong with this vi, I am attaching the vi. I will really appreciate if someone can resolve this before monday !!
Thanks a lot !!
(2,617 Views)
Have you resolved this problem yet?
Mark
(2,617 Views)
Dunty,
In MAX, verify that - in addition to correct configuration - you can read proper values in the Test Panels. Once your readings look good in the Test Panels, try running an example program. In LabVIEW, go to Help>>Find Examples. Search by the keyword "1100" to find the Thermocouple example. Using these steps, you can narrow down the source of the issue. Good luck with your application.
(2,617 Views)
