vi written in Labview 8.2 not working in labview 8.5
I upgraded labview on my PC. Older version was 8.2 and now I have 8.5.1. But, the vi and program that worked well in labview 8.2, no more works. I notice that some of sub vi are not recognised in labview 8.5. A sample vi is attached. Pls suggest what to do.
Thanks in advance
rsd
errors like following, are reported;
poly VI 'Daqmx Timing.vi':sub VI is not executable.
similar errors are reported for create virtual channel, Daq mx write and Daq mx start task.
(2,861 Views)
you can keep on following the discussion on the other forum you posted:
http://forums.ni.com/ni/board/message?board.id=250&message.id=45357&jump=true
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(2,842 Views)
