vi written in Labview 8.2 not working in labview 8.5
I upgraded labview on my PC. Older version was 8.2 and now I have 8.5.1. But, the vi and program that worked well in labview 8.2, no more works. I notice that some of sub vi are not recognised in labview 8.5. A sample vi is attached. Pls suggest what to do.
Thanks in advance
rsd
errors like following, are reported;
poly VI 'Daqmx Timing.vi':sub VI is not executable.
similar errors are reported for create virtual channel, Daq mx write and Daq mx start task.
(3,224 Views)
Accepted by topic author rsd111
You just need to reinstall the DAQmx driver. You can find the latest driver at Drivers and Updates.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,221 Views)
yes, you should try to re-install the last version of DAQmx driver, making sure of installing the support for LabVIEW 8.5. Verify that you have folder C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\DAQmx.
Bye.
Licia
(3,194 Views)
