01-17-2007 08:42 AM
01-17-2007 11:43 PM
First of all, what is the voltage range that your sensor gives??
Check if you are reading that channel on MAX, using the same mode in which mode had you connected the sensor on SCB 68 ( Diffferential, RSE, NRSE)
Have you selected appropriate AI range for that channel??
01-18-2007 05:42 AM
Thank you for your reply.
I am using a sensor array, actualy. There are 6 sensors arranged on bases- 2 bases have no sensors attached. When measured at output pins, the sensors (which are mere voltage droppers) gave 1.5 - 2 V on the average. I have built a circuit to give amplification of 2 or 3 times.
I have been using MAX for my investigations so far. I chose differential as my AI input mode. The range selected was -10 to 10 V. My observation is that i got same noisy values on all chanels - including ones without sensors
01-18-2007
04:32 PM
- last edited on
07-18-2025
09:17 PM
by
Content Cleaner
Hi rrd,
You said that you are using differential as your AI input mode. What channels are you using? When using differential as your AI input mode, you need to wire the positive terminal to channel x and the negative terminal to channel x+8. The sensors give 1.5 to 2 volts and you amplify 2 or 3 times with a custom-built circuit. Have you tried to measure the noise without the amplification circuit? It is possible that the circuit is introducing additional noise into the system. You may want to try not amplifying the signal.
Here are some great resources regarding noise:
Developer Zone: Field Wiring and Noise Considerations for Analog Signals
Best Regards,
Erik J.
