what are the meaning of sample per buffer and cycle per buffer? How to use them?
I found them in example.But I don't know why use them? what are the meaning of sample per buffer and cycle per buffer? How to use them?
(3,703 Views)
Hey Yun_Zhu,
What example are you looking at?
The samples per buffer is how many sample points there are per buffer output.
The cycles per buffer is how many cycles of the signal there are per buffer output.
You can also look up some more about how they afffect the AO Update Rate here.
Hope this helps you out!
Joe S
(3,690 Views)
Thanks Joe s
(3,676 Views)
