06-17-2011 02:50 PM
Can someone explain what single-point I/O is? I've been reading about it a lot but don't fully understand it and it's a potential criteria in choosing the right bus for my application. Thanks a lot!
06-17-2011 03:32 PM
If you are going to ask a question about something you have read, post a link to it.
What I think of single point I/O would be taking a single sample of a waveform as opposed to multiple samples with a specific time between samples so the entire waveform is captured. This is not relevant to what I would define as a 'bus' so I'm really not sure what the heck you are thinking about.
05-10-2013
02:11 PM
- last edited on
11-17-2025
02:34 PM
by
Content Cleaner
I had that question while reading this:
"The RIO Scan Interface provides single-point updates to I/O variables at rates up to a few hundred Hertz without requiring FPGA programming."
It was from here:
http://www.ni.com/white-paper/14138/en
05-13-2013 12:27 PM - edited 05-13-2013 12:28 PM
Hi Over_Nyquest,
Single-Point I/O is generally known as software timed acquisition or non-buffered acquisition. Basically, single-point I/O means that only one data point will be read in from the hardware to the software at any point in time. So data will not be placed on a buffer and then brought in to the software in chunks.
-Jake B.
