Multifunction DAQ
where can I find AI.llb
I have installed a PCI-6023e and bnc 2110, it runs, can run the tester, I have downloaded various demo app's to test the board, ALL need .vi's from AI.LLB, where do I find AI.llb ????????
(3,180 Views)
Have you installed NI-DAQ for the version of LV you are using?
Ben
(3,180 Views)
If you can run a test panel in Measurement and Automation Explorer (MAX) (I'm assuming this is what you mean when you say "run the tester"), you have NI-DAQ installed. You will need to install support for LabVIEW when installing NI-DAQ (that is what will install the AI.llb). Reinstall NI-DAQ and include support for LabVIEW when you reinstall. This should fix the problem. I hope this helps.
Todd D.
Applications Engineer
(3,180 Views)
thanks, that did it, at least in part, I can now get the single and dual channel scope demos running...
I tried a few others downloaded from NI site and they are asking for yet more .vi's I do not have. I guess my main issue here is that we have bought a lot of new but prior owned cards that have software/drivers from year 2000....
anyway I'm off and running now
Graham
(3,180 Views)
