why can't vista find the driver for DAQCard-6036E
I am trying to install a PCMCIA card DAQCard 6036 on a vista based laptop but when i insert the card it is recognised but vista cannot find a driver on the labview DVD or Driver CD's. Is there a driver available?
Message 1 of 8
(5,124 Views)
Hi there ,
When you bought the card, you should have recieved the Daqmx driver along with it. When you say that the card is recognised, are you able to communicate to it via MAX or Labview?
Make sure you disconnect your device when installing your driver. If you do not have DAQmx, the latest version can be downloaded from here.
Message 2 of 8
(5,104 Views)
Hi again,
I am sorry for being hasty, but DAQCard (PCMCIA) support for Windows Vista is not available for NI data acquisition devices. For laptop-based measurements with 16-bit resolution, please consider NI DAQPads or USB M Series.
Message 3 of 8
(5,095 Views)
This was 2.5 years ago.  There's still no support for DAQcards in Vista?  Why has this not been addressed?
Message 4 of 8
(4,549 Views)
Where did you get the information that there is no support? Did you look at the support page? Did you look in the readme for the current driver - DAQmx 9.0.2?
Message 5 of 8
(4,542 Views)
I got the information from Vista when it could not find the driver for my 6036E.  I'm using DAQmx 9.0.1.
Message 6 of 8
(4,533 Views)
Is it Vista 64? Only Vista 32 is supported according to the link.
Message 7 of 8
(4,512 Views)
Yes, it's Vista x64, which I only upgraded to when I discovered that NI would not be supporting XP x64 for ANY drivers.  Now I find out that expensive cards which my company has purchased from NI must be replaced with USB devices which did not exist until long after the DAQCards were acquired.
Message 8 of 8
(4,506 Views)
