Multisim and Ultiboard
14.0.1 print setup broken
I just got 14.0.1 update today.  So far OK, except the print setup is broken.  I've never seen this before, but now I have to go into every sheet and set the print options up.  When doing it on page one and saying print entire design and setting the setup to default I get only the first page correct, and then every other page with a different zoom factor (they were 100% rather than fit) so only partial pages printed.
I had to open each sheet and separately set up that sheet's print options to get it back doing what it was supposed to do again.
I hope this is fixed soon.  I have a 45 page design I'm going to work on and it will suck to have to set each sheet up separately to print properly.
Do I get dibs on first 14.0.1 reported bug?
(3,968 Views)
Hello Dbur,
I will have to verify if there is any CAR reported for that. However if you have any suggestions you can use the idea exchange forum:
http://forums.ni.com/t5/Multisim-and-Ultiboard-Idea/idb-p/multisimideas
Randy @Rscd27@
(3,949 Views)
Six years later and this still isn't fixed.
(1,343 Views)
