Multisim and Ultiboard
Multisim-Live, Transformer
Hi, I was trying out the 1p1s transformer to simulate an AC/DC voltage regulator.
I was stuck with the transformer when I could not get the voltage I wanted, so I tested the transformer with a 1:1 turn ratio and found the primary and secondary voltages is not the same.
Is there something that I am missing?
(2,703 Views)
You need to use a "reference point" for the voltage Measurement.
(1,631 Views)
Землю потеряли, прога не знает от чего начинать считать , поэтому-врёт...
(1,621 Views)
