Multisim and Ultiboard
1hz clock circuit
Hello All,
I am a college student using MultiSim 12.  I have a need to generate 1Hz and 2Hz clock timer circuits using the Student Edition of MultiSim.
I am not having success finding designs which can utilize MultSim's pre-existing components.
Can anyone propose/provide information on how to generate 1Hz/2Hz timer circuits using MultiSim Student Edition ?
Thanks You
(8,168 Views)
If you look under components, Sources-> Signal Voltage Sources, Clock Voltage should be in there and you can double click on the item and change the parameters from 1KHz to 1 Hz.
(8,150 Views)
Thanks Nutmegzz -  for the information on clock sources within MultSim.
My current question is about building a 1 Hz timer circuit using the passive/digital components with MultiSim student version.
Would have any information on the design schematic/worksheet to build a 1 Hz clock circuit ?
Thank You
(8,143 Views)
 A 555 timer is a common part that can be use to create clock source and it's in the Student edition.  There are lots of online resources for this component.
Tien P.
(8,139 Views)
Accepted by CollegeStudent
Hello Tien,
Thanks for the feedback on using the 555 timer.
(8,116 Views)
