Multisim and Ultiboard
2SK216,2SJ79 SPICE model for Multisim?
Hi,,
 I have the 2SK216 & 2SJ79 SPICE model files as following :
*src=2SK216;QSK216;MOSFETs N;Gen. Purpose;200V 500mA
.MODEL QSK216 NMOS
(LEVEL=1 VTO=15 KP=80M GAMMA=18.6
+ PHI=.75 LAMBDA=521U RD=.84 RS=.84 IS=250F
PB=.8 MJ=.46
+ CBD=658P CBS=790P CGSO=26.4N CGDO=22N CGBO=852N)
Assumes default L=100U W=100U --
* 200 Volt .5 Amp 6 ohm Enh-Mode N-Channel
MOSFET 07-28-1995
* 2SK216, TOSHIBA, 1993 JAPANESE FET MANUAL,
P.38
*src=2SJ79;QSJ79;MOSFETs P;Gen. Purpose;200V 500mA
.MODEL QSJ79 PMOS
(LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.04M RD=.84 RS=.84
IS=250F PB=.8 MJ=.46
+ CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N
CGBO=1.09U)
* -- Assumes default L=100U W=100U --
Enh-Mode P-Channel MOSFET 07-28-1995
* 2SJ79, TOSHIBA, 1993 JAPANESE FET
MANUAL, P.16
I copy and paste the model in Multisim, but it can't work!!!
Could you  make the 2SK216 & 2SJ79  as the "prz" file?
  I think import the prz file will be easy to finish.
(7,762 Views)
What's your Multisim version? Place the components you created on a blank Multisim file and attach it here for troubleshooting.
Fernando D.
(7,744 Views)
hi,
My multisim is V12 ,
please download and and anlyse the attach file.
Thanks!
(7,735 Views)
The main problem here is that the Multisim SPICE engine is expecting a model with four pins, however these models only have 3 pins. You need to add a .SUBCKT statement to to tie the S and B pins together. Take a look at this KnowledgeBase:
How Do I Import a MOSFET Model into Multisim?
The new model (for the 2SK216) looks like this:
.SUBCKT MOS D G S
M1 D G S S 2SK216
.MODEL 2SK216  NMOS(LEVEL=1 VTO=.1 KP=60M GAMMA=18.6
+ PB=.8 MJ=.46 CBD=658P CBS=790P CGSO=26.4N
+ CGDO=22N CGBO=852N)
.ENDS
Attached you will find the 2SK216 component I created. Multisim is understanding the model however I don't know how accurate the model is, just give it a try.
Fernando D.
(7,725 Views)
Thanks Fernando D.
But the 2SJ79 is  still not working ,would you help me?
regard
(7,713 Views)
Basically you have to follow the same procedure, in this case the edited model is:
.SUBCKT MOS D G S
M1 D G S S QSJ79
.MODEL QSJ79 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.04M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N CGBO=1.09U)
.ENDS
Attached you'll find the component I created for you.
Fernando D.
(7,687 Views)
Thanks Fernando D.!
Now I can use the model for my job.
regards
(7,666 Views)
