Multisim and Ultiboard
555 bistable
A) I'm also not able to reproduce it with your simulation settings.
If you find a fixed way to reproduce it, then please let me know so that I can report the behavior.
C) It's indeed that one.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 31 of 33
(1,548 Views)
I think the error got fixed by using the "set initial conditions to zero"-setting (why isn't that set default?) in combination with the Convergence Assistant that did this:"-Shunt resistance from analog nodes to ground (RSHUNT) was changed to 100000000", no idea what the previous/default value of that setting was.
Message 32 of 33
(1,525 Views)
I am having same problem. Can anyone locate the fault? My design is attached.
Message 33 of 33
(1,406 Views)
