Multisim and Ultiboard
74LS11D
Something seems to be wrong with the 74LS11D TTL IC that came with my MultiSim 10.1.197.
The pin labelled 2Y seems to be 3Y, and the pin labelled 1Y seems to be 2Y.  I'm still trying to figure out what's what.
Is there a fix for this component?
(6,073 Views)
Hi there,
I took a quick look and it looked OK to me. Attached is the datasheet that I used. Do you have the original circuit or datasheet?
Yi
Software Developer
National Instruments - Electronics Workbench Group
(6,041 Views)
Attached is a simple test circuit for the component.
Excuse my technique - I'm a novice.
(6,033 Views)
You might have attached the wrong schematic. There is no 74LS11D in the schematic that you've attached.
Yi
Software Developer
(6,027 Views)
That's weird.  Attached is a screenshot of what I see when I open it.
(6,025 Views)
I right-clicked the 74LS11D and replaced it with the 74LS11N.  The 74LS11N works fine.
My problem is solved, because the 74LS11N will work for what I'm doing.
However, you might want to investigate further the 74LS11D which came with my software.  Let me know if I can help with that.
(6,018 Views)
Accepted by ledwig
Hi ledwig,
I am sorry, you are right. I had the wrong file open and getting confused. Your suggestion of using the 74LS11N is a good one. The only difference is the footprint that it maps to in layout. There is a problem with the model that comes with the 74LS11D. It is a relatively easy one to fix and we will try to have it worked out soon.
Thanks for reporting this!
Yi
Software Developer
(6,011 Views)
