Multisim and Ultiboard
74LS283 not working
Hi
I am running MultiSim13.0.1. So, I needed a 4-bit adder and I downloaded it from here.. http://forums.ni.com/t5/Circuit-Design-Suite/I-am-missing-some-components-in-MultiSim-Verson-10-1-1/...
So, when I used it in my circuit, the output was the exact complement of what was expected. I made a new test circuit using the adder and it was working fine. Then I pasted that test configuration in my circuit and still the compliment result. I deleted everything except the test circuit from it and still the compliment result. Finally I tried to copy paste what was left in a new blank design and it is working fine.
So, the design I am attaching gives the wrong result and when I copy paste it exactly same to a new blank design it works as it should. Any help is appreciated.
(5,481 Views)
Hello kushgpt23,
I tried runing the diagram that you posted and it ran without prmpting any error. I  also tried copying it and pasting it in a new blank page but it worked just the same.
Could you please clarify what is exactly the "wrong" and "right" behavior that we should expect to observe?
Regards!
Daniel C.
(5,380 Views)
Sorry I posted the wrong file. The right onw is attached herewith.
The "wrong" result I am getting is the complement of what the result should be. My adder (there is only 1 instance in this circuit)  inputs are 1000 and 0X00 where X is a periodic wave. So, my output should be 1X00 but I am getting 0(~X)11.
(5,373 Views)
