Multisim and Ultiboard
74LS74N simulates in 10.0.343 but not in 10.1.197
A 74LS74N simulates in Multisim 10.0.343 but not in 10.1.197.
I used the same circuit file in both Multisim 10.0.343 and 10.1.197.
This is the error message from Multisim 10.1.197:
SPICE Netlist Error in schematic RefDes 'u3', element 'au3_b[du3.2d du3.not2pr du3.not2clr du3.2clk]':
Invalid component name 'au3_b[du3.2d du3.not2pr du3.not2clr du3.2clk]'
SPICE Netlist Error in schematic RefDes 'u3', element '<unknown>':
Due to errors, the component 'au3_b[du3.2d du3.not2pr du3.not2clr du3.2clk]' has been omitted from the simulation
(4,830 Views)
I get this error when I have only one section hooked up but both section on the schematic. If youn are only using one half of the component try deleting the other half. Also make sure all inputs have something connected to the component whether that be ground or VCC as required.
I hope this helps. If you need further assistance please post your Multisim file so we can examine it.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,824 Views)
I attached the file PickChopperCycle.m10.
I redid all the connections to U2 74LS74N.
The circuit simulates correctly in Multisim 10.0.343, but not in Multisim 10.1.197.
Thanks for your help.
(4,807 Views)
This is probably going to be the strangest explanation and possible solution that I have ever done.
First, I did try your circuit and recieved the error message. The reason I dd not get this yesterday was because I was only using 1/2 of it and not the other half in conjunction with the first half.
What I did first was to replace the second half of the component and have it use a diferent Reference Designator like U3A. This made the circuit work with no error messages displayed. This did not make sense that you could only use one half a a dual component and get error messages when using both of them contained in one reference designator i.e. U2a U2b. So I suspected a problem of some fashion with the Master Database where this part is concerned so I decided to try and isolate what may be causing this. I copied the component to my User database so I could edit it if necessary. I looked at my newly transferred component and it said it was a single component with 8 pins. I edited this to make it a dual component with 14 pins.
To make a long story short, I replaced the one in your schematic with the one I  created in my database and now everything seems to work and no error messages. The only thing I can figure is that there may have been a template error for this component in the master database and by me putting it in the user database it refreshed and corrected the template, I am just guessing on this last part as I do not really know why the new one works and the Master Database one doesn't.
I am going to include 2 files for you. The first is a .PRZ file for the component. This will automatically place it in your user database. Just open it like any other Multisim file. The next is your schematic with this part in it. Let me know if this works or not on your end.
Have a Nice Day
(4,789 Views)
I read in the *.prz file and tried your circuit. Simulates OK! Great!
(4,786 Views)
