Multisim and Ultiboard
How do i instatiatemultiple groud in a plane?
I'm making a design in which i've multiple ground s(AGND,DGND,PGND).
I've 4 layers. one is dedicated to the grounds(the third).
i want to divided this layer for the 4 grounds.
how do i realise it?
the second layer is dedicated to power signal.
How do i realise it(just the power net muss be routable here)
sorry for the question i'm a newbie.Smiley Wink
thanks
regards
(4,019 Views)
Hi willb8,
when you use the Netlist Editor (Ultiboard->Tools->Netlist Editor) you have the ability to specify for every net seperately on wich layer in shall be routed. This is possible from the spreadsheet view too. I think this is it that you are searching for.
Additionally you can add "Net Bridges" to mechanically connect your different ground signals.
District Sales Manager
(4,009 Views)
Thanks oyster for the answer.
How kann i divide my ground plane, then i've 3 of them?
Do i realize this with "place-> copper Area"?
Do i need to flood a plane in Ultiboard?
Should my Ground me declare as a power plane? what's the difference?
thanks
regards
(4,003 Views)
you can place copper areas and assign them to a specific net.
The power plane automatically fills everything that is possible with the desired net.
(3,992 Views)
