Multisim and Ultiboard
Adding tube models to multisim
I cannot find the folder where you can add spice models to the Multisim student edition. When I was using the trial version, I was able to just copy a folder that had spice info for different tubes into the Multisim file that holds all of the models. I can't seem to find it in the student edition. How do I go about doing this?  Thank you for any help.
(5,442 Views)
PLease?!!!
(5,416 Views)
What component are you looking for? I can upload it for you.
The SPICE model you need is likely on the web, Google part number + SPICE and when you find the model create your own component.  If you don't know how to do this, refer to this tutorial:
http://zone.ni.com/devzone/cda/tut/p/id/3173
Tien P.
(5,413 Views)
I was hoping I didn't have to go through all of that. When I used the trial version at school, we simply downloaded a spice model and copied it into the multisim file that holds all of the models. I was then able to access it and use it to build a circuit. Is this not possible with the student edition? I primarliy work with tube amplifiers, and after purchasing the student edition was sad to see that there are only a few tubes. I would hate do have to go through all of that for every tube I need to use.
(5,411 Views)
The Student Edition have fewer components than the Education Edition and unfortunately, you have to add the model.
Tien P.
(5,408 Views)
That is very sad news....Thanks for your help. I'm sure I'll be back when I get to trying to add components!!
(5,398 Views)
