Multisim and Ultiboard
Use picture as copper
Hey all!
I have a bitmap with a specified pcb design. When 'place' it into Ultiboard under a copper layer, I can clearly see the design. Only when I turn to 3D view there isn't any copper in the shape of the bitmap visible... How can this be? Is it not possible to use a bitmap as conductive material?
Felix
(3,165 Views)
Hi Felix,
I can replicate this problem in 3D view and I will let R&D know about it.  If you export the Gerber file, the bitmap info should export.
Tien P.
(3,143 Views)
