Multisim and Ultiboard
BTA 06 component enquiries
I need BTA 06 component to do some simulation but i can't find then in multisim v11. Anyone can help me to create it? Thanks!
Message 1 of 8
(5,254 Views)
You must contact component manufacturer for a component's model.
Then, refer to Multisim Help>>Components and Database on how to create a component.
Message 2 of 8
(5,236 Views)
The Model is BTA 06. but i am not really sure how to set the right parameters that is on the SCR for simulation. ^^
Message 3 of 8
(5,234 Views)
Hi, the Spice model contains the component's parameters.
For this component (BTA06-600B) exist a SM, but is very simple
.subckt BTA06-600B A K G
X1 A K G Triac_ST params:
+ Vdrm=600v
+ Igt=100ma
+ Ih=50ma
+ Rt=0.065
+ Standard=1
* 1999 / ST / Rev 0
.ends
For similars components ftp://ftp.alsdesign.fr/Upload/libusers/Triac_st.lib
Regards
Message 4 of 8
(5,204 Views)
Thanks!
Message 5 of 8
(5,200 Views)
By the way, how to merge it to multisim as there are a lot of diodes and triacs in the package? I hope to hear from you soon. Thanks!
Message 6 of 8
(5,198 Views)
If you create the component, you have to check PLACE>COMPONENT>DATABASE>USER DATABASE
where is commonly save
Regards
Message 7 of 8
(5,177 Views)
ok. but how to add the spice code for the component? there is some code from the previous post but it seems to be different from the generated code from the model maker ^_^ I tried to use the model maker but it appears to be not working as SCR
Message 8 of 8
(5,174 Views)
