Multisim and Ultiboard
Battery Connection
 How can I have a battery connection in multisim? I have a simple LED circuit using VCC power and a ground. But when I export to ultiboard there is no connection to a battery. I need a place to have to solder holes so I can solder the 9v connector for the battery to the board. Any idea on how I can accomplish that?
(5,597 Views)
Hi Qbasic8,
You will need to use a connector. They are in the Basic Group Connector Family. Just connect your power and ground to the connector and then you will see the footprint in Ultiboard.
Tayyab R,
National Instruments.
(5,586 Views)
A screen shot is attached.
Tayyab R,
(5,584 Views)
Hey, thank you very much. 😃  Exactly what I was looking for.
(5,574 Views)
