Multisim and Ultiboard
How can I generate a gauss function in multisim?
Hello together,
I would like to generate a Gauss function (source/voltage) in multisim
I hope anybody can help me.
Message 1 of 10
(5,658 Views)
how to create gaussian pulse as source???
Message 2 of 10
(5,648 Views)
help me....
Message 3 of 10
(5,644 Views)
pls...
Message 4 of 10
(5,636 Views)
Accepted by topic author anm
Hi anm,
I have a solution for you. What you can do is use excel to generate the values for your guassian function. I have attached screen shots with this post.
After making the function, you can copy paste this data into a notepad window and save it as a .txt file.
In Multisim, there is a Piecewise_Linear_voltage source which can use the values from the .txt file as the input.
Then you can use this as the source for your circuit.
Hope this helps.
Tayyab R,
National Instruments.
Message 5 of 10
(5,625 Views)
anm,
My preference is to use a LabVIEW based Multisim VI option (built for Multisim v11).   Place the zip contents in the /lvinstruments folder and go from there...
If you like this VI, you'll like my waveform calculator VI for Multisim (https://decibel.ni.com/content/docs/DOC-17216)
Happy simulating..
Pat Noonan
Message 6 of 10
(5,616 Views)
thanks you so much.....
love u all... hehe...
Message 7 of 10
(5,593 Views)
Cannot find the LabVIEW instrument "LVInstrIF1000/gaussianpulsev1". The following instrument(s) will not work properly:XLV1??
that means??
Message 8 of 10
(5,590 Views)
anm,
What Multisim version are you using? The instrument was built for Multisim v11.
If it's an older we'll need to build in LV 2009 or earlier.
Pat
Message 9 of 10
(5,583 Views)
Hi anm,
Did you copy paste the two extracted files into the C:\Program Files\National Instruments\Circuit Design Suite 11.0\lvinstruments directory?
Tayyab R,
Message 10 of 10
(5,577 Views)
