Multisim and Ultiboard
Battery voltage disabled
HELP!
I'm not sure how I managed to do this, but when I go to vary the battery from 10 Volts to 12 Volts I cannot do it.  The value field is "X" out and marked restricted.
What did I do?
(3,983 Views)
Please help!
I have somehow managed to get the value field tab for all of the components set to "Restricted"  Because of that none of the workbook examples can be used.
(3,969 Views)
Accepted by topic author don.farr
Hi Don,
I believe you have accidentally activated the circuit restrictions.
This can be disabled by going to Options > Circuit Restrictions and unchecking the Hide component values checkbox.
Jason
(3,959 Views)
Jason,
That was it.  However, when I first looked at that, the The "Hide Value" was unchecked.  I then checked it, ran a test and then unchecked the box and it worked correctly.
Thank you!
(3,949 Views)
Okay,
I did it again and now I get prompted for a password prior to being able to get to the circuit descriptions.
Two questions:
1) How am I accidently changing this setting?
2) I have entered a password for "Global Restrictions".  But I never set up a password for "Circuit Restrictions".
It appears that I have accidentially found a method that selects a password for the "Circuit Restrictions" and then changes the properties of a Master Database component, "DCPOWER"
I do I fix my error and prevent it from happening again?
(3,711 Views)
