Multisim and Ultiboard
Best way to add noise to circuit
I currently have a circuit built around the AD8333 demodulator which outputs the something close to a dc voltage when switch is on. I want to add noise before my demodulation and still get the same nice output and have been having a lot of trouble with that. Could someone help me? Attached is the circuit with a scope where you can see the output I am shooting for.
(7,776 Views)
Hi Renan,
There is a thermal noise source in the "Sources" group under the "Signal voltage source" family.
You can also try to use this noise source created in LabVIEW:
https://decibel.ni.com/content/docs/DOC-28305
Tien P.
(7,726 Views)
