Multisim and Ultiboard
Generic ADC spice
Hi all,
       I'm going to run simulation by using the generic 8-bit ADC in Multisim.  However, I have to change some parameters of this generic ADC to test performence in different cases. Here is the spice code of the ADC:
.subckt ADC8 vin vref+ vref- F0d F1d F2d F3d F4d F5d F6d F7d clk eoc PARAMS: conversion_time=1u
xU3 clk EOC_clk ONESHOT PARAMS: pulse_width={conversion_time}
a2 EOC_clk eoc DELAY
.model DELAY d_delay(rise_delay=2n fall_delay=2n)
a1 Vin [F0 F1 F2 F3 F4 F5 F6 F7] Vref+ Vref- ADC_core
**FFs
ab0 F0 ~EOC_clk DGND DGND F0d 100 FF
ab1 F1 ~EOC_clk DGND DGND F1d 101 FF
ab2 F2 ~EOC_clk DGND DGND F2d 102 FF
ab3 F3 ~EOC_clk DGND DGND F3d 103 FF
ab4 F4 ~EOC_clk DGND DGND F4d 104 FF
ab5 F5 ~EOC_clk DGND DGND F5d 105 FF
ab6 F6 ~EOC_clk DGND DGND F6d 106 FF
ab7 F7 ~EOC_clk DGND DGND F7d 107 FF
.MODEL ADC_core ew_nla2d( )
.MODEL FF d_dff(clk_delay=1n set_delay=1n reset_delay=1n ic=0 rise_delay=1n fall_delay=1n)
.subckt ONESHOT in out PARAMS: pulse_width=100n
aU8 in 4 DIGITAL_DELAY
aU7 4 2 NOT
aU6 [4 2] 9 AND2
aU5 in 1 NOT
aU3 [in 1] 6 AND2
aU2 U2_OPEN_S U2_OPEN_R U2_OPEN_CLK 6 9 out U2_OPEN_notQ SR_FF
.MODEL SR_FF d_SRff (clk_delay = 1n set_delay = 1n reset_delay= 1n ic = 0 rise_delay = 1n fall_delay = 1n)
.MODEL AND2 d_and ( rise_delay = 1n fall_delay = 1n)
.MODEL NOT d_inverter (rise_delay = 10n fall_delay = 10n)
.model DIGITAL_DELAY d_delay (rise_delay={pulse_width} fall_delay={pulse_width} delay_type="transport")
.ends
           It's extremely helpful if someone can tell me what's meaning of the parameters. Like what's the ".model DELAY d_delay"? is it the  whole adc delay? And what is the ".model DIGITAL_DELAY d_delay"? Besides, could I know the structure(connections and gates) of this ADC?
Best Regards,
Laffer
(5,629 Views)
Hi Laffer,
This model is based on XSPICE and not spice, you can download the manual and other resources from here:
http://users.ece.gatech.edu/mrichard/Xspice/
The ADC model is made up of various core parts such as AND gate, flip-flop gate etc... connected together to create ADC model.
Just to give you an idea, this section in the model:
Anything beginning with "a" is call function and it is calling a model name "Delay",  the 'EOC_clk' and 'eoc' are nodes connecting to the delay model.
The .model part is the model for the "delay
Tien P.
(5,581 Views)
