Multisim and Ultiboard
Bug report about create new footprint with Rounded rectangle in 3D info Bottom
I create new footprint with rounded rectangle in 3D info Bottom,the rounded rectangle must be in bottom,but In fact,the rounded rectangle
created in top layer.i think it's wrong.
I used ultiboard 10.1.357.
(4,133 Views)
I am a bit confused about what you mean. Are you talking about the round rectangle's appearance when you click Tools>>View 3D?  Or are you talking about the location of the rounded rectangle after you place the component? Or do you mean something else? Please clarify and if possible, can you post an Ultiboard file?
Thanks!
Yi
Software Developer
National Instruments - Electronics Workbench Group
(4,119 Views)
here is the Ultiboard capture file.Three object are green,must in bottom layer,and the other in red must in top layer.
Now,you can see the rounded rectangle in top layer. I think it's wrong!
(4,112 Views)
Thank you for reporting this. This has been a long standing issue with Ultiboard and we are looking into resolving this.
There is a work around although a very inconvenient one. You can set the height to what you require and use a negative offset to move the shape to the other side of the board. The 3D shape will appear on the other side, but in reality is just shifted, not mirrored.
Hope that helps. We apologize for the inconvenience.
Yi
Software Developer
(4,087 Views)
