Multisim and Ultiboard
Can I turn off netlist numbers in multisim?
Can I turn off netlist numbers in Multisim?  Or is there some other way to keep netlist numbers from being displayed?
Thanks in advance.
(8,056 Views)
Accepted by VI_Joe
To turn off displaying net names on your schematic:
  1. Go to Options > Sheet Properties. The Sheet Properties dialog shows.
  2. Select the Circuit tab
  3. In the Net Names box, set to Hide All
These settings are sheet (page) specific. Depending on your design, you may need to specify this for multiple sheets.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(8,042 Views)
