Multisim and Ultiboard
Can't find some components in multisim Component master Database
I Couldn't find the following components in the multisim database during schematic design phase of my circuit.
Can you please provide the models for the components or point me the location and method for manually designing a new component.
The attachment has all the information about the circuit and the component connections..
STM32F103CB
Info :   STM32 32-bit ARM Cortex MCU
URL : http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF189782
MPU-6050 / MPU-6000
Info :  INVENSENSE - GYRO / ACCEL
URL: http://in.element14.com/invensense/mpu-6050/gyro-accel-9-axis-fusion-i2c-24qfn/dp/1864742
BQ24075
Info :  Power-Path Management IC
URL : http://www.ti.com/product/bq24075
TPS79301
 Info :  Single Output LDO
URL : http://www.ti.com/product/tps79301
MAX16054
Info : On/Off Controller with Debounce and ±15kV ESD Protection
URL : http://www.maximintegrated.com/datasheet/index.mvp/id/5879
NUF2221
Info : Upstream Terminator with ESD Protection
URL : http://www.onsemi.com/PowerSolutions/product.do?id=NUF2221
nRF24L01+
Info:Ultra low power 2.4GHz RF Transceiver
URL:http://www.nordicsemi.com/kor/Products/2.4GHz-RF/nRF24L01P
 Narendra Varma
(7,667 Views)
narendravarma,
Typically SPICE models won't exist for most MCU parts, the others you may not be able to find models for.
Creating the models can be difficult, but its relatively easy to create the symbol/pinout for these parts and attach the symbol pins to an existing or new footprint (for layout).
Multisim only (create symbol, connect a model (optional) and connect a footprint (optional):
http://www.ni.com/white-paper/3173/en/
Ultiboard (for a new PCB footprint) - not needed if you can reuse an existing footprint (over 5500+ exist already)
http://www.ni.com/white-paper/5631/en/
Pat N
(7,625 Views)
thank-you  for your reply ....
but is there any way I could create a symbol  and model it  such that it be used in the  simulation ...
for checking some characteristics of the  circuit .... atleast upto  some  extent ...
Narendra
(7,606 Views)
