Multisim and Ultiboard
How to take out rms voltage from a AC source supplying a load
Using immurement probe I could just measure the RMS voltage/Current. But I need to take out that value and feed it as input to a another circuit block.
Please help me in providing some circuit design to take out RMS voltage. I have tried using some default circuit for "RMS to DC Conversion" using some ICs, but its not working.
Is there anyway that I could take out RMS voltage?
(6,840 Views)
There are several ICs from Analog Devices in the database listed under:
Master Database -> Analog -> SPECIAL_FUNCTION
Also, here is a generic one that I've created you can use (it scales by ~ 10 Vrms : 1Vdc)...
Pat Noonan
(6,787 Views)
Thank you so much for your help.
It works 🙂
Vimal
(6,783 Views)
