Multisim and Ultiboard
Can you make component values visible globally
I wish to make the component references invisible and values visible so that I can generate a printout that only details component values.  It was possible in previous versions of ultiboard to do this globally, is it possible to bo the same in version 9?
(6,033 Views)
Set the selection tool to just components.
Use the editi menu  to select all
Then use the edit menu the edit properties
Now choose the attributes tab to set the values to visible. Works in ultiboard 7
MPC
(6,028 Views)
