Multisim and Ultiboard
Changing copper area from solid to dashed
When I place a copper area, this is a solid surface. How can I change that to a dashed area?
(5,758 Views)
To change a copper area;
1.) Double-click on the copper area
2.) Select the "Copper Area" tab of the properties dialog box
3.) Select the appropriate fill in the Fillstyle drop-down box on the right hand side of the dialog
This should let you change it to the required fill style.
(5,755 Views)
