Multisim and Ultiboard
mulitple pins
What I am trying to do is create a MOSFET part that is in an SO-8 package. I want to display the symbol of the MOSFET, and have the package be an SO-8. The problem is that the part wizard(The name is a joke) won't allow me to assign a multiple pins with the same name. So how do I go about this?
See the attached file
Patrick
(6,487 Views)
The part I am woking with is an NDS8434 Thanks
(6,483 Views)
There are two options for to create this component.
  1. Create a symbol with all the pins showing, but each of the pin must have a different name you can call pin D1, D2 etc…
  2. You can create a symbol with only three pins, when you do the pin mapping it is possible to assign multiple pin to the same symbol pin.
(6,454 Views)
