Multisim and Ultiboard
Change footprint for fuse in Multisim?
Hello Guys,
I encountered a problem when using the Multisim and Ultiboard (Version 10.1), i'm using a fuse in the circuit, but the footprint can't be changed, when doing a forward annotation to ultiboard, i always need to change the footprint of the fuse. Do anyone has a solution on this issue?
Toni
(7,197 Views)
Hi Toni,
Could you provide some more information, such as the exact fuse in the database that you're attempting to use? Is the issue that you're not allowed to change/add a footprint to this fuse in Multisim? Or that it is not being transferred properly to Ultiboard?
Natasha
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(7,171 Views)
Accepted by stop
Hi Toni,
Have you tried modifying the footprint in the spreadsheet view? Try doing this:
  1. Make sure that the spreadsheet view is visible in Multisim. Click View>>Spreadsheet View. By default, the Spreadsheet View is at the bottom of Multisim.
  2. Click on the Components tab of the Spreadsheet View
  3. Click on the Footprint tab of the fuse you want to modify
  4. The Edit Footprint window should appear and you should be able to modify your footprint
If that doesn't work, would you mind uploading your Multisim design for us to take a look at?
Hope that helps.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(7,170 Views)
Hello Natasha,
Thanks for providing me your help, i'm using a 50mA Fuse in the master database and I can only use the software recommended, and now I succeed changing the footprint to a customized shape following Yi's suggestion.
Regards
Toni
(7,138 Views)
Thank you, Yi.
Now i get it.
Regards
(7,136 Views)
You are very welcome!
Yi
Software Developer
(7,124 Views)
I have the same issue in Multisim 11.  I need to change the fuse footprint,  Why does this have to be more complicated than changing a footprint for any other part? (I love Ultiboard, but Multisim has some serious issues, like how difficult to search for parts when trying to replace component, terrible symbol editor, etc but thats a story for another day)
In my case, there is no "components tab" in spreadsheet view.  What do I do now?  I need to replace this fuse to "clean up my design".  Its annoying that this is the only component on my artwork that does not forward annotate properly and I have to change the model everytime I tranfer the netlist file.
Help!
(6,423 Views)
