Multisim and Ultiboard
Circuit problem
I won't leave this time with an empty post , i promise. I've posted same thread, i left due to other circumsances. Won't leave this time without finishing,
Anyways,
Unfinished circuit2 is my uncomplete circuit. Screenshot_600 is a complete circuit of what im suppose to do.
Anyhelp could be greatly appreciated.
(6,255 Views)
I've just upadated my circuit adding oscillioscope, thank you.
(6,246 Views)
I understand my circuit very well, just don't know how to construct it.
"The circuit is for simulating what happens when an inductor is selectively charged via 50 Ohms then discharged via 20 Ohms. A current probe around the wire leading to the inductor senses the current through the wire/inductor and provides an output of 1mV for each mA of current. This output is monitored on the 'scope. The charge or discharge function is selected with the switch.
There is nothing special about the resistors (but in a real circuit they would have to handle high currents)."
(6,237 Views)
Accepted by WJWMJ
It's finished now, i managed it so figure it out myself. Hope everything looks right, can anyone confirm, perhaps a professional advice?
(6,223 Views)
R5 does not appear to match the specification you quoted (5 ohms vs 50 ohms).
Are the results what you would expect from solving the circuit analytically?
Lynn
(6,201 Views)
I would imagine, it should work like that. Thanks for your reply.
(6,162 Views)
