Multisim and Ultiboard
Component tolerances: random distribution selection
When performing a Monte Carlo analysis, you can select the individual tolerance values and distributions in the "Model tolerance list."  The default distribution is Gaussian, but you can select Uniform for any parts you want.  My question is, how would you switch all parts to have a default Uniform distribution in a single step?  Swapping individual component distributions on a large design is very painful!
-J
(3,267 Views)
 Hi J,
You have to individually change the setting for each component, the option to change all components setting at the same time is not available, I will create a feature request for this issue.
Tien P.
(3,227 Views)
