Multisim and Ultiboard
Config File Issues
I currently use MultiSim version 10.1.1.  I use it in my classroom in a
high
school.
The issue I'm having is that the config file seems to change and I can't
change
it back.  Some stations now have blue icons on the top where the drop down
menus are suppose to be.  When you click on a blue icon nothing is there to
pick (component).  I try to change the config file back but it won't let
me.
Please help.  I'm not sure if my students are doing this.
(4,057 Views)
Have a look at this knowledge base, I think it will fix this problem:
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/2719d00e36a4d53a8625721300685b3f?OpenDocument
In 10.1.1, select Options>>Lock Toolbar turning this option on may prevent this problem from happening in the future.
Tien P.
(4,024 Views)
When I click on your link I get the following error.
While trying to retrieve the URL: http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/2719d00e36a4d53a8625721300685b3f?OpenDocument
The following error was encountered:
Unable to determine IP address from host name for ae.natinst.com
Is the link correct or maybe the server down?
(4,012 Views)
I am sorry about that, this is the link I wanted to post:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P97gSAC&l=en-US
Tien P.
(4,008 Views)
Ok.....did that.  I still cannot place a component.  The component menu is grayed out under the place tab.  Also when I go to the toolbar and click on a component, the menu that comes up is empty.
suggestions???
thanks
(3,996 Views)
Have a look at this knowledge base:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9adSAC&l=en-US
Tien P.
(3,992 Views)
