Multisim and Ultiboard
How to calculate the base resistor of a transistor ?
I was checking the pic up-down counter tutorial circuit, below.  I want to know how the base resistor was calculated.
transistor type: BC557AP  working as a switch
Base resistor: 4.7 k ohm  (R3, and R11)     <== How this was calculated ??
Display bus resisotors: 270 ohm  (I don't know if these are necessary in calculating R3 and R11)
 Thanks in advance
(4,963 Views)
any kind of help will be aprreciated
(4,948 Views)
Rmax=(Vdd-Ube)/Ib, Ib=Id/hFE
Ube - Base to Emitter voltage (0,65V), Id - Display current, hFE - DC current gain BC557
(4,936 Views)
