Multisim and Ultiboard
Connecting Vias Together in an inner layer
I'm new to Ultiboard, and I've placed two buried vias between the same two inner layers. How can I put a trace between them on of the inner layers?
Thanks!
(4,634 Views)
Please have a look at the routing tutorial from the following to learn the different methods to route a trace in Ultiboard:
http://www.ni.com/white-paper/6880/en
I don't understand you question so you may have to elaborate.  To route a trace from one via to another on the same layer, the procedure is as routing to two pads.  However, if you want to route a trace from one layer to anther using a via, have a look at the following knowledge base:
http://digital.ni.com/public.nsf/allkb/7F94E89D05FEE01D86257A620065FE00
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
(4,586 Views)
