Multisim and Ultiboard
000 to 999 counter Circuit LCD Not working Help
I am trying to outline the design for my project for my circuits class I am pretty new to Multisim, but I have tried everything to get the 7 segment 4 digit LCD and or 3 7 segment Hex to display properly I am not sure if its something wrong with my circuit orthe software. I hooked a logic analyzer to the outputs of the counter 4516B IC so I know that it is counting. There must be a error in the way I am connecting my driver 4543s Please help so that I can begin physically building this circuit and wire wrap.
Thanks in advance.
(5,608 Views)
working logic analyzer
(5,605 Views)
Have a look at the attached file; I've isolated the two parts you mentioned so that you can see how they work. Press the key A, B, C and D on you keyboard to control the inputs DA to DD and you can see the results on the 7 segment display.
U17, I've turned on the symbol pin name so that you can see which pin is which. A1 to G1 are part of the first 7 segment LED.
Here is a datasheet for the 4543:
http://www.nxp.com/documents/data_sheet/HEF4543B.pdf
I hope this helps.
Tien
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
(5,570 Views)
