Multisim and Ultiboard
Importing a SPICE model into Multisim from Fairchild
I am trying to import the following model into Multisim: http://www.fairchildsemi.com/ShoppingExperience/action/redirectModel?type=model&filename=FDV305N.mod
The SPICE model is for a N-Channel MOSFET.  It contains a 4th pin, for temperature.
I am not sure how to add this fourth PIN to Multisim, or how to remove the 4th pin from the SPICE model.
*FDV305N at Temp. Electrical Model
.SUBCKT FDV305N 20 10 30 50
*20=DRAIN 10=GATE 30=SOURCE 50=VTEMP
*TEMP SECTION
ED 101 0 VALUE {V(50,100)}
VAMB 100 0 25
.ENDS FDV305N
*FDV305N (Rev.A) 7/1/02 **ST
(7,376 Views)
The model includes temperature effects.
You would have to use the symbol editor within the Componen Wizard to add a 4th pin to an existing 3-pin Mosfet symbol.
I created the component for you. The pin on the right side is this temperature pin. Apply a voltage (1V = 1degC) to simulate at the desired temperature.
Max
(7,371 Views)
Thank you very much.  Could you explain exactly how you did that.  I was unable to figure it out myself.
(7,355 Views)
There is an article that shows you how to use the Comonent Wizard:
http://www.ni.com/white-paper/3173/en
If you do not require a layout footprint, then skip all those sections regarding footprint. Ensure to select "Simulation only" in step 1.
In the symbol step, click "Copy for db" to select a symbol already used by an existing component. Then click Edit to enter the symbol editor where you add any extra pins.
Max
(7,350 Views)
I did:
Tools -> Component Wizard
Component name: FDV305N
Simulation Only
Componet Type: Ananlog
Number of pins: 4
Add a 4th pin to an N-enhanced FET
4th pin name: Tj
Load model from file: FDV305N.mod (from fairchild.com)
I get this error: http://i.imgur.com/loA8RYY.png
Alan
(7,308 Views)
well it tells you that ANSI and DIN symbols do not match with respect to pin count. You can ignore it if you're only using ANSI symbols in your schematics.
Max
(7,305 Views)
