04-23-2013 12:57 PM
I am trying to import the following model into Multisim: http://www.fairchildsemi.com/ShoppingExperience/action/redirectModel?type=model&filename=FDV305N.mod
The SPICE model is for a N-Channel MOSFET. It contains a 4th pin, for temperature.
I am not sure how to add this fourth PIN to Multisim, or how to remove the 4th pin from the SPICE model.
*FDV305N at Temp. Electrical Model *------------------------------------- .SUBCKT FDV305N 20 10 30 50 *20=DRAIN 10=GATE 30=SOURCE 50=VTEMP ..... *TEMP SECTION ED 101 0 VALUE {V(50,100)} VAMB 100 0 25 ..... .ENDS FDV305N *FDV305N (Rev.A) 7/1/02 **ST
04-23-2013 02:58 PM
The model includes temperature effects.
You would have to use the symbol editor within the Componen Wizard to add a 4th pin to an existing 3-pin Mosfet symbol.
I created the component for you. The pin on the right side is this temperature pin. Apply a voltage (1V = 1degC) to simulate at the desired temperature.
04-24-2013 10:58 AM
Thank you very much. Could you explain exactly how you did that. I was unable to figure it out myself.
04-24-2013 12:19 PM
There is an article that shows you how to use the Comonent Wizard:
http://www.ni.com/white-paper/3173/en
If you do not require a layout footprint, then skip all those sections regarding footprint. Ensure to select "Simulation only" in step 1.
In the symbol step, click "Copy for db" to select a symbol already used by an existing component. Then click Edit to enter the symbol editor where you add any extra pins.
04-29-2013 03:19 PM
I did:
Tools -> Component Wizard
Component name: FDV305N
Simulation Only
Componet Type: Ananlog
Number of pins: 4
Add a 4th pin to an N-enhanced FET
4th pin name: Tj
Load model from file: FDV305N.mod (from fairchild.com)
I get this error: http://i.imgur.com/loA8RYY.png
Alan
04-29-2013 03:26 PM
well it tells you that ANSI and DIN symbols do not match with respect to pin count. You can ignore it if you're only using ANSI symbols in your schematics.
