Multisim and Ultiboard
Connecting holes to header pins
On a normal header (2x15) I would like to outline it with 15 holes on each side, that are connected to the header pin it's next to. How do I go about this? Do I need to create these holes in ultisim and connect them there and then place them in the proper positions in ultiboard or can I just use Ultiboard?
Very thankful for answers
____________
/Peter Hygren
(6,733 Views)
I don't see a way of doing this through Multisim. You will have to export your circuit as is without the holes and add them in Ultiboard.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(6,722 Views)
Ok, so how do I go about this? Do I edit the part and add holes? How do I connect them? All I get i DRC's when I try this...
____________
/Peter Hygren
(6,714 Views)
I have a file for you to look at. Let me know if this is what your looking for. If not maybe you can post of picture of what you are wanting to do. This is the only way to do this that I know of except for using vias.
Have a Nice Day
(6,702 Views)
Precisely, thank you!
____________
/Peter Hygren
(6,688 Views)
