Multisim and Ultiboard
Connector pins (72) spread over 4 shts of schematic
P1 has 72 pins, How do I show the pins over 4 sheets of a schematic. I cannot find a symbol for multiple pins that can be shown or used as a single pin.
Re: P1-pin 13
      P1-pin 43
      P1-pin 42              All going to an IC
Then others going to a different IC. Both inputs and outputs from the connector.
Can anyone tell me why resistors and caps are foot printed by metric sizes instead of decimals. I still cannot be sure of the size for a simple RLR07 resistor or a CKR05 cap? Nothing meets Mil spec sizes.
Thanks for the help.
Scotty544
(4,268 Views)
Accepted by scotty544
I made a 72 pin connector and used off-page connections to get a net. Made a footprint for the connector in Ultiboard and tied the 2 together. It worked, the board is routed.
(4,129 Views)
You had me stumped earlier, but I thought of what I think is the 'right' solution. If the pins you want are different on all pages, you could have created a multi-section component, and place the different sections on different pages.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,099 Views)
