Multisim and Ultiboard
Control "Unconnected" Font Size Visibility
How can I control the font size and visibility of the "Unconnected" and "Name:"  annotation that appears for an unconnected pin.  I have one that is huge in the middle of my board from a custom part I created.  I want this pin unconnected but don't need it splashed across the board design.  I've searched through the Part, Global, and PCB Properties and cannot find how to control this.
Any ideas on how this is controlled and how to hide it or make it rationally small?
(3,214 Views)
The pin name should be the same as the drill size I am thinking you may have pins on top of each other.  Can you post a file with only this component on the forum?
Tien P.
(3,137 Views)
