Multisim and Ultiboard
powerplane and board edge error
I am using UB 10.1.197
The powerplane will offset from the board edge correctly on rectangular boards, but connects the plane to the board edge on internal radiused corners. See Attached Photo.
I have not experienced this problem in previous versions.
Any thoughts?
MET
(3,448 Views)
Hi Met,
Is it possible to post a file with only the board outline, I like to create a defect for this issue?The work around is to place a small keep out near the problem area so that the copper area will disconnect from the outline.
Tien P.
(3,348 Views)
