Multisim and Ultiboard
ControlledThreePhaseRectifie
open the folder:
Power Conversion---》AC-DC---》ControlledThreePhaseRectifier
click  the U1,where is  the Delay time?
how i can set the pulse angle?
(4,861 Views)
The phase angle is set dynamically using a voltage applied to the alpha pin. 1V means 1degree. Notice that the example applies 30V to this pin, meaning a 30 degree angle.
Max
(4,851 Views)
thank you very much,i will try it later.
(4,831 Views)
you mean the pulse angle is the trigger angle of the Thyristor?
(4,827 Views)
it is my projet (the follow file).
(4,823 Views)
Uou use the alpha pin as an ideal control pin. If set to it a voltage of 0 Volts, the firing angle will be 0 degrees. If you set to it a voltage of 30 Volts, the firing angle will be 30degrees.
Max
(4,812 Views)
